nitrous selection
voidfinger
well thats cool b/c who wants to spray in 2nd but not 3rd? right? lol its a pretty neet feature. But can't you do a dual shot set up on it too? like a 100 hp dry and then a 150 hp wet in the next gear.
95PGTTech
no, it works by "running through" the cycle. you select the number of run throughs, and that selects your first gear to spray in. for example, if you're like me, you've had it on zero run throughs and never changed it...sprays 1-2-3-4-5 and if equipped 6, 7, 8, etc.
if you select one run through, it means it runs through the rpm cycle once...as in, if you set it 4000rpm and one run through, the car accelerates from 0 rpm to 5000 rpm, that's the run through, it ran through the duty cycle. you shift, it drops you to say 3500rpm, as soon as you hit 4000rpm it sprays. if you select 2 run throughs, it runs through first, second, then sprays 3, 4, 5 etc.
after seeing how cool this thing is and how many features it has, it won't be long before I start running a progressive controller.
voidfinger
now the progressive controller is what i'm talking about isn't it :santa_smiley: regardless that is a neat little thingy. When i get my wet kit from them, thats one of the things that is a must for me. Don't want to be going down the track and have ::D happen. If you know what i mean
