No iso's?
lilj4u2njoy
Forest City, NC
So I have been reading alot and I always keep seeing people say they have no isolators, what are the benefits? Does it change ride quality? Will it squeak? Thanks
GT Rob
Houston Texass
Without them it lowers to car more but not by much and some people put ducktype where they go depends on the person I have my fronts off and the rears are on
lilj4u2njoy
lilj4u2njoy
Forest City, NC
Okay so duct tape, lol... That makes it not squeak? Classy... Well reason I ask is right now I have 19's on the car but and looking to go to maybe a 17 inch wheel and I'm concerned that I won't have the same stance, and yes my car is lowered but I just don't want a huge gap between the bottom of the wheel well and top of tire
joekd
Ct
I said why risk it and put in all urethane iso's when I redid my suspension
lilj4u2njoy
lilj4u2njoy
Forest City, NC
Well I have new ISO's but like I said I'm curious if my gap will get huge with a smaller wheel or will the cars weight make it sit like it does now?
Sent from my EVO 3D using tapatalk
vermilion
maryland
1. there is a suspension subforum.
2. the isos main purpose is prevent metal to metal. removing them relieves almost .5 inch compressed. to the naked eye thats not anything substantial. Duct tape does work but it chaffs away.
good luck.
mygreengt
South Dakota/ Iowa
if you are going with a smaller wheel, you will have a taller sidewall on your new wheels, rather than a 19" wheel with a small side wall. so the fender to tire gap will be close to the same.. amiright?
JoshHooten
Hiram, GA
I have no rear iso's , And wrapped jut the top and bottom coil in black electrical tape "the springs are also black" just to keep it from being metal on metal .
I have never heard one squeak out of the suspension or had any problems .
Slykin
Tyler, Texas
No point to it IMO, but it's your choice. I'm not running them in the bottom rears because they were old.. but they will get replaced soon. Just seems like a half assed way to do it.
JoshHooten
Hiram, GA
I did it for another .4 to .5 drop, springs will only give you so much drop if you truly want to go low you will have to take them out or get some coil overs .
Slykin
Tyler, Texas
Coilovers is my plan lol. But, then again comfort is fairly high on my priorities seeing as my car is already running on blown shocks and I DD my car. No need for me to make it worse.
JoshHooten
Hiram, GA
Very true I have ford c springs with 3/4 coil cut and no isos in the rear and it rides like stock , there not stiff like the eibachs .
Ford recommends cutting the dead coil on the rear springs if you want the car to drop a little more .
This, if you buy the same diameter tire the stance wont change.
lilj4u2njoy
lilj4u2njoy
Forest City, NC
So to have the same diamter current I have 19 in wheels with a side wall of 30... What size sidewall on a 17 inch wheel will I need to keep the same diameter? 40?
98rocket
i don't run iso's. The rear springs make a slight noise when turning into a driveway, but nothing else..
joekd
Ct
Depends on the width of the tire, 245/45/17, 275/40/17, etc
Here, have fun plugging in numbers, just pay attention that the old and new diameter are about the same
http://www.miata.net/garage/tirecalc.html
dutch
I can hear the springs sometimes going over speedbumps, but other then that nothing. No squeaks or anything.
