No power
d.garza18
TEXAS
can any of the wiring gurus chime in! I’m working on my buddies 2003 Gt. He was driving it the other night, hit a bump and lost all power to the blinkers, headlights taillights etc. gauges still work. I’ve check every fuse and everything is fine. Both inside and out. I’ve poked around and I’m getting power. Any idea what this problem could be?
by "checked every fuse" do you mean you have literally pulled and inspected every fuse or that you pulled the 2-3 that you thought would be related and checked them? Did you check under the hood as well?
Addicted
Kentucky
Headlight switch or relay, I'm spitballing here. There was an electric guy that was absolutely very skilled with that stuff called "WMBURNS" he was on "allfordmustangs" forum. He helped everyone with electric problems. Search under his name in those forums, because I use his stuff as references when I was talking to you yesterday. I hope you get it figured out bro.
d.garza18
d.garza18
TEXAS
I checked, only two I found that weren’t good were
d.garza18
d.garza18
TEXAS
d.garza18
d.garza18
TEXAS
Still doesn’t make sense to me though, how would him hitting a bump cause all of this mess if it’s just a fuse?
