Not starting!???
G_94_T
TN
Bought the car about 3 weeks ago....124000 miles,BBK cold air and MAF,stock exhaust with no mufflers(previous owner).....drove the car to work Fri. morning and ran fine,got off work that afternoon and started the car but it kinda stumbled a bit and died,now it wont fire AT ALL...turns over fine....the car is still at work so i couldnt do a whole lot with it .I did swap out the coil but didnt help.I didnt/cant check the fuel pressure but the fuel pump sounded sick...so is that the problem...anyone else been in the same boat?...'94 5 speed
this is my 2nd SN95...the first was a '94 too but i had to sell it a couple years ago...
1bad95
pump still priming when you turn the key on? my guess would be the dizzy is bad
I know the fuel pump is quite audible on my car, if you can't hear it I'd say it's a good starting point. You can also pull a spark plug and see if it has fuel on it... can also do a spark test to see if it's the dizzy like Bad said.
G
G_94_T
TN
well apparently it was the pump...i installed a new 190 and it fired right up....thanks for the help/advise guys!
