NPI Cams ??
MY97GT
What are the best cams I can 'drop' in a 97 2V nPI motor to get the best HP increase?
steedastang
I went with Crower stage 3's. If i were you i would go with stage 2's. You will also need springs and a tune. You wont pick up to much power unless you swap on a better intake as well. Once you do that it will open up pretty well. Then go with long tubes.
Jrgunn5150
The Crower NPI stage II is the best off the shelf NPI grind, IMO. You will need spring's though.
