Obd code
stroked95
I keep getting the code 511 on my car. Any know what is causing this? It does have a sct chip in it. Also when I did the balance test I get 1 3 7 any info on that one?
Thank you for your time,
Tim
Venom351R
Maine
The lowest code in my book is 11 and that is system ok reading. So Im not sure where you are getting a 1, 3, 7 from? And yes a 511 is b/c of your chip.
rz5.0
Great state of TEXAS
1,3,7. Are the cylinders that are showing to be weak.. You could swap out the injectors then run the test. Or do a compression test to make sure..
96GTPlanB
