Oil like substance in odd place.
Twista
Hey guys i can't figure this one out. Its been leaking for awhile and i dont think its coming from the coolant gasket (which is crappy) but its holding up good enough for me (yes i see the green marks on the RTV) :haha:
Anyone seen oil in this area before? Its been like this for awhile now.. with the combination of coolant leaking from the waterneck+oil from where ever its caked up in the area as you can see. The waterneck is not really leaking bad anymore so i doubt its that. The power steering pump was bone dry before i topped it off so i can't say its coming from either because i dont see how it would get there. Looks like its coming from under the intake??
JoshHooten
Hiram, GA
mine is doing the same exact thing . I replaced my timing chain cover a few months back and I cant figure out where its coming from either
ill let you know if I find out.
96TANGERINEGT
they make uv oil die to find it the only bad thing is u need a black light to see it .
u could prob. find it that way
framda
Naples, Fl.
Clean it all real good. Remove all of the oil and grease. Once it is clean, you can isolate where it is coming from because the area of the leak will get dirty first.
Venomized
Iowa
Everyone telling you the intake is the culprit is right. Our cars are notorious for intake seal leaks at the front and back seal.
framda
Naples, Fl.
Speculation is just that, clean it off (which you have to do anyway). See where it gets dirty first. That is where it is leaking.
gopher_6_9
Loretto, TN
Unfortuantly on a 5.0L alot of times that will not give you a definitive answer. The distributer and intake sealing area are so close 90% of the time you can't tell where the actual leak starts. Pulling the intake is not a big deal, get a intake gasket kit and reseal it. When you do you have the dist. out anyway so replace the o-ring. Easy and you know it is right.
