oil pan questions
98fobra
Can I use a crown vic oil pan and pickup tube on a mark8 motor in my mustang
98fobra
Its still in the car I want to seal this motor up before I pull the old one out so its just a faster r&r
Musturd
Oh yea makes sense , I'm not sure if the crown Vic one works actually
sort-of.
the crown vic motor is a 2v engine. the mark 8 is a 4v engine. the 4v engines ran with a larger oil-pick up. Although the 2v may bolt up to it, it would limit the oil run through the engine.
the oil pan should fit.
conclusion: get a 4v oil pick up tube and use the crown vic oil pan.
full force
I have pan and pick up for 96-98 Cobra if you need one, 440-476-4114then you KNOW it works... dont mismatch P/U and pan without checking clearance....
