oil pressure gauge
infamous209
I am going to buy a oil pressure gauge and dont know whether to get a mechanical or a electrical and where to tie it into. Can anyone help me? Thank you!!
Willis_98GT
DFW Texas
Under the oil cooler (where your oil filter is) their is a plug where the stock sending unit is that you can thread into, a big sender wont work with you very well because the stock k wont let You
Mustanger
Southern Oregon
No, the electrical gauges are nothing like what we have stock. Presently we just have a temp switch that gives a reading in the dash gauge say low, normal & Hot. The electrical gauges have a temperature sender you install that gives a continuous analogue signal of the temp. to the new gauge. You get to see all the temps as they change & these gauges can be very accurate. They are so much easier to install with no chance of a tubing leak inside your car, or kinking the tubing. I much prefer the electric gauges over any mechanical ones.
SRT Handz
I have a Electronic Oil pressure gauge. I installed the sensor right under the oil filter in the empty oil. Works like a charm.
Justang
I also have an electrical OP gauge, and no complaints here. If I remember correctly, I T'd off where the stock sender is and put a sender on each end.
vermilion
maryland
the difference is the mechanical gauge uses a teflon or copper tube that pushes a diaphram in the gauge. an electrical uses signals through a box. both of which are accurate. the stock is junk.
I
infamous209
Finally stopped being lazy and got back on here, I am going to get an electrical gauge and I do know the difference between the electric and mechanical gauges, just didnt know what yall were going with. Thanks guys, good to be back on here.
