p1sc procharger questions
jedpony
Pittsburgh PA
Picked up a p1sc for my 95 gt. Will be running around 11psi with a 3.4 pulley 8 rib setup with a 3 core intercooler. My car just has the basic bolt ons, full exhaust. Will i need a fuel pressure regulator? I already have a walbro 255lph fuel pump and 42# injectors. Also would i see any benefit upgrading to a gt40 intake manifold with a 75mm throttle body? Any suggestions would be very helpful. Thanks.
Musturd
The gt 40 intake would for sure help it breathe a little up top . I'd also run a adjustable fuel pressure regulator as well
J
jedpony
Pittsburgh PA
Thanks for the input musturd. Would i see a good amount of difference in lets say a trickflow intake to justify the cost?
Musturd
I'd just throw a cheap gt40 on it instead of forking out for a high dollar intake on stock heads
ivan12
You're going to need a tune to get it running right, don't see the point in dropping $ on a AFPR
J
jedpony
Pittsburgh PA
looks like im picking up a 94-95 svo ford motorsport intake manifold. Apparently its the same as the cobra intake. What size throttle body should i run 70mm or 75? I read that the cobra intakes opening is 70mm.
