my manual is not recent enough to cover pats but I wasn't aware it has anything to do with door triggers. The key and the ignition sure but how does it tie into the doors?
Will make another tests these days. Hiwever I want to put a 20A switch to the radio to manually toggle complette on off. But still there is the drain on the HD LPS fuse which need more time to find out
OEM keyless entry module in the trunk seem to have a short or somewhere in its wiring. I unplugged it and the drain dropped from 0.3A to 0.02A
Earlier I have installed an aftermarket remote and this one has to be hooked up to the both wires of driver and passenger side door lock actuator and voila!
