Parking Brake Too Tight
sleepn_sn95
Indy
After installing my MM LCA's yesterday (which required disconnecting the e brake cables) my passenger side caliper is now dragging while driving. The e brake handle was accidentally pulled while the cable was disconnected and I believe this adjusted it tighter. How do I loosen it or reset the adjustment? Everything I've read online is just for tightening it up.
Thanks
Burninriverdiver
When I change rear pads on most vehicles the parking brake almost always drags. A little pb blaster and a few pulls on the inner cable with pliers usually loosens things up for me. If the parking brake was functional before then this should hopefully work
07GtS197
Fort Myers, Fl
If bedding the pads or using pb blaster doesnt work then yes there is an adjustment nut on the side of the e brake handle hidden by the console. I wouldnt touch it just yet though.
g36 monkey
Orlando, Fl
Disconnect the cable from the caliper and give the metal part a really good tug to get some extra slack out of the sleeve
sleepn_sn95
sleepn_sn95
Indy
Well I pulled the wheel off tonight to take another look at it. Turns out there isn't a return spring on the caliper on that side. I disconnected the cable and the parking brake now releases as it did before. It could never hold my car alone on my driveway and it's back to that lol. I still dont know what was going on before with the cable connected and no spring. At least I can drive the car now
DKblue98GT
Well, that would certainly make a difference. Glad you got it sorted. Car looks awesome!
stillridin
