5L5SpdHardtop
- Joined
- Apr 19, 2009
- Messages
- 9
- Reaction score
- 0
Hello, I'm new to the forum. I've seen some good tech advice during my browsing so I thought I might be able to find an answer to my PCV system question. I bought my 95 GT some time ago. The more I get into the car, the more I see that the previous owner had no business attempting repairs. I have been slowly repairing any problems I find, many created by the previous owner. The problem I'm having is a terrible squealing noise very similar to a slipping serpentine belt. The noise only occurs when the engine is warm and under high vacuum, such as at idle or light throttle. If I shut the car off while it's making the sound, the squealing subsides very slowly as though pressure is bleeding off somewhere(the belt has stopped spinning a good 3-4 seconds before the sound stops). I have noticed that the crankcase builds excessive pressure, which led me to believe I might have a problem with the PCV system, thus leading me to my main question. My PCV hose currently exits the top of the PCV valve and travels a short distance to a "T" fitting, which then has one line that branches off and connects to a fitting on the underside of the upper intake, and one line that goes to a 90degree fitting on the end of the upper intake closest to the brake booster. The "T" doesn't seem necessary to me and I have no other cars in the area to look at for reference, so I can't be sure this isn't more of the previous owner's molestation of the car. I have a new PCV valve and filter for it, but I'm not sure if the routing is correct. Currently, my only other suspect for this problem is the hacked up air injection system that's on the car. If anyone has any input for my problem, it would be much appreciated.
