phenolic spacer size?
What is the biggest spacer that you can put on a cobra/gt40 intake? I have been considering adding nitrous to my 94 but would like to use a plate if I can. I found one but the plate is 5/8" thick, I though 3/8" was the thickest we could use with the stock hood?
my 3/8 rubs the hood blanket in one corner already so I know 1" is waaaay too big. I am sure I will have to loose the blanket but If that is the case I do not want my intake rubbing the raw hood....
94califiveoh
my stock hood bearly toucher my intake with a 1" spacer, including two gaskets. Hood closes without a problem
95-stang
1" spacer is usually too much for most, 5\8ths is just over half an inch so you should be good.
