pi motor and five speed swap
mach1197203
I just came across a 04' that was totaled. GREAT PRICE. I want to swap the PI motor and 5 speed into my 96'. does anyone know how hard this is going to be and what all I need to take from the donor car? :headbang: :headbang:
dafizuck
Engine, wiring harness wouldnt hurt, trans, pedals, trans crossmember... im sure theres more. Get everything you can.. hah.
nrk
uncltrvlnmatt said:
Take everything that is good from the car and sell the rest. I mean everything.
x2,
swapping just the motor, trans, and computer over might fuck with the PATS, I recently swapped steering columns and it's not fun running into problems with PATS.
ryeguy2006a
as long as you swap the computer, steering column with key and cluster you should be fine.
RareBreed
you could use the stock ecu if you are going from auto to 5 speed. I did the same thing when I installed the Tremec in my 98, but went with a custom chip to compensate for the change.
