Please Help - Horn Doesn't Work
Tommy Starss
Ok well i got my car it was a v6 i switched everything over when i bought my second sn95 that was a hardtop gt i took the motor trans suspension rear wheels brakes computer everything my horn dosent work since i had my motor done i was wondering if there is anything different from the two years but an answers would be helpful thanks a lot guys
94kingcbra
Re: Please Help
It could be a wire, it could be the horn relay, the switch, or the horn itself. If you were able to do a big conversion like that I think you will be able to find the problem. All it will take is a multimeter and some patience. I would start with the relay then at the horn switch on the steering wheel, then the horn. Easy stuff first, then let us know the progress Good Luck!
if all that checks out good then the clock spring may have broken. it's the thingy inside the steering wheel that allows the wheel to be turned and still have everything on the wheel work. and it's under the airbag crap too so be careful
T
Tommy Starss
Thanks guys i rewired it there was a short in the wire and my clock springs did go bad i got them from cjponyparts and ahh thanks for the comments on my car i appreciate it :thumbsup:
