Please help with electrical issue.
Blakonblak94
Ok guys, I have no fuses blown, but my blinkers, fogs, and dashlights are out of commission. However my airbag lights stays on. Just stays lit the whole time. My emergency flashers work, as well as my headlights, and windshield wipers. Any suggestions guys?
mikey94gt
Check your multi function switch... its the one that the turn signal stalk is attached to.
toyman
Fogs and dash lights (illumination) have a common connection in the headlight switch. Turn signals could be an issue with the multi-function switch. Recheck fuses 1 (turn signal) and 5 (headlight switch) or just replace them to verify they are not the problem.
Blakonblak94
Blakonblak94
My fogs are no longer wired into my Headlight switch, they are wired into my convertible harness so I can use them as daytime lights however they are used as an accessory with only being on with key on.
mikey94gt
Hm.... the only other switch I can think of that is common to all those is the ignition switch. last time I had a problem with running lights, turn signals, hazards, etc, it was the wiring to/from the multi function switch and the switch itself.
topless95
your best friend would be a test light/multi meter and a wiring diagram. Be careful of blindly replacing parts, as you may be replacing good parts and not getting any closer to solving your problem.
Blakonblak94
Blakonblak94
Ok so I went outside and tinkered a bit. I have my fogs wired up to the convertible plug for the fog light daylight running lights setup. They will not come on either. I'm starting to get confused. I have no blown fuses, and Im not sure what to check for power. I have a service manual but wiring diagrams are by far my weak point in automotives. Once again, my emergency flashers work, headlights work, windsheild wipers work as well as my flash to pass. However, my dash and hvac lights, along with my fog lights and blinkers do not work.
