pliego23 need help bad
pliego23
has any one use helicoil on a head boit and how muck is a helicoil kit 7/16-14 rated for?????????????
stang94X
when you say head bolt, do you mean the bolt that bolts the head down, cause if so dont do it and why would you need a heli coil for that, if youre talking about the bolts that hold the acc brackets to the head, i used em and it works fine
P
pliego23
its in the block its like 1/2 in little peace put its does not want to come out i use the two def. easy out tools nop the person that had the car befor had only water in it so it bad
94 DropTop
that sucks dude sorry to hear it. i hope mine dont break when i go to take them out. for about 8 months i was running mostly water
screech
Guest
yeah, I stoped reading when i seen it was your block. honestly laughed at the thought of someone thinking to helicoil there block.
by the picture, you a hawaii 5-0 fan I take it.
Paul
A properly done heli-coil is as strong or stronger than the original threads.
How the heck did you strip the threads on an iron block!?!?! :)
