I just put in new ball joint less than 1k miles ago and the front end still pops when hitting some bumps, slowing down at a stop sign or sometimes taking off. Its not very consistent either as I can't always replicate it. It popped before the new ball joints but it seams like it got worse after the new ball joints or maybe I am paying more attention now? the old ball joints actually didn't even look bad and appeared to have been replaced in the past and were moog ball joints. I replaced the inner and outer tie rods at the same time, only one inner tie rod had play but I figured if I was doing one to due them all. The steering has no slop now and has a fresh alignment. I also replaced the front sway bar end links with quality moog units. I tightened the k-member to body bolts and all other bolts I could see including shocks mounting bolts etc. I even cut 1/8" off of the sleeves that the steering rack mount bolts go through so that the rubber bushings would be tighter, this made the steering more responsive. So after all of this it still makes the pop sound as I described with no improvement. The only thing left to replace is the bushings on the lower control arms and I can't get those to move at all with side to side pressure with the car jacked up. What could this be?
