fastgtfairlane
- Joined
- May 20, 2007
- Messages
- 966
- Reaction score
- 2
alright, i was really bored friday and decided to make some modifications to my throttle body. i saw a pic of a car that had the 94-95 tb on his car with out the elbow. so i modified my intake manifold and made a plate to block the egr hole on the tb flange. anyhow got it it all bolted up. i have a typhoon intake and taking the upper off the gasket ripped up. so i used some rtv on the surface. i set it up and let it sit for about 45min before i put the upper on so it wouldnt all squeeze out when i torqued it down. while the upper was off i took the end plate off and cleaned up some of the casting inside the intake. gasket also came apart. put some rtv on it too. anyways, at wot it is spark knocking only in first and second gear. in 5th at wot it doesnt spark knock. im thinking i may have a vacuum leak but not sure. gimme all of your thoughts.
with the tb mod, it turned out pretty well. i will post some pics.
