Daryl
Actually it’s the resistor plate that has one hole larger than the otherif the holes are the same size, it won't matter on gasket
give me bit lookingActually it’s the resistor plate that has one hole larger than the other
Thx, John! Yep, just as I suspected: smaller home to the front. Just double-checking my memory ;-)
YouTubeI still have the 8mm coil wire from the set I’ve just replaced, which is basically brand new “super performance “ (?) set from VatoZone . It works and fits on as it should, but it’s 8mm and the new wires are 9mm, so I’m not sure if that makes a difference???you will need to crimp the correct end on it or replace the cable
Just for the future, you can take apart any sparkplug wire or coil wire and swap ends as they are just crimped onI ended up calling Summit asking if I could swap the male end coil wire for a female. Of course they don’t sell the FP 9mm blue wires separately and I wasn’t keen on plunking down another $70-80 for a second set just to get the coil wire.
Feeling we were at an impasse, I asked, “what’s this extra spark plug wire?” Turns out it’s a coil wire…. just a LONG ASS coil wire. Guessing for setups with a firewall mounted coil. So, I popped it on, fit as it should, and to rid the excess slop wrapped it around the top of the distributor. Kinda hanky I know, but the length made it work pretty much perfectly. Picture o follow.
Sidebar question: saw a YouTube where the guy had a rubber cover that went over the distributor and really cleaned up the wire runs to each bank. Anyone know what it’s called and are they good, bad or “eh” to have??
I’d prefer to do that using the shorty coil wire. The way I have it now looks ridiculous. So do I chop the wire off at the boot or Armstrong the boot off and swap the the female end? Will any brand female cap work?Just for the future, you can take apart any sparkplug wire or coil wire and swap ends as they are just crimped on
You can slide the boot off and then pry back the crimp on the wire. Little lune on the rubber boot helps it slide on and off. Not a complicated processI’d prefer to do that using the shorty coil wire. The way I have it now looks ridiculous. So do I chop the wire off at the boot or Armstrong the boot off and swap the the female end? Will any brand female cap work?
Interesting. Then what the heck’s in there?if you do this, do not be surprised when you do not see any actual wire inside.
