power steering return line universal?
x182dan
I was wondering if there is anything available except the universal stuff? The line is leaking right at the pump and it looks like its the return line since all the fluid is sitting right on the bracket and dripping down right onto my oil filter and ground. All I can see available is the universal return line, I cannot see that working because the return line takes a sharp 90* turn right after the pump. The line is just clamped right onto the steel line that goes right next to the radiator. I have double clamped the line onto the pump and that didn't help any. Any ideas?
Dan
wayne94mustang
in the past on other cars i have used simple fule line for the return....its not under pressure and this worked for me.
as far as the bend and looking neat you could always bend it out of hard line and just use rubber at the ends.
X
x182dan
I was just afraid that the straight line would kink because of the 90
RoadZOmbie
I used it and has been working for the past year. You wont go wrong with the universal.
