power steering
94-5.0GT
well couple months ago when my clutch went out, i got my car towed. well they fuck up one of my brakes lines so i replace it and bleed the brakes. then like a couple weeks ago i moved my car since it was nice out. when i was driving it my power steering like went out on me. I was lost so i parked and there was no power steering fluid. any ideas? i didnt see other lines broken
95-stang
Well it has to be leaking at either the pump, the rack, or the two hoses in between the two.
As one pipe is the low pressure return its usually in most cases the high pressure line that bursts, if its one of the pipes at all.
Put some new fluid in and check out where the leak is.
95-stang
You can get them cheaper, but if you log in to Summit they do some good looking racks, reconditioning a power steering rack properly is not cheap, so beware of anyone offering them at very cheap money.
You could get one from a breaker [as long as its not front end damage] same with the pump if its the pump.
