Pre motor build questions
mtang98 gt
Before I go buying the largest cams and porting my PI intake manifold I need some advice on what I should do and not do.
Since I have the PI heads on a non PI motor I know there will be a bump in compression will that be a negative or positve thing I do not plan on boosting or spraying, Also i plan on running a 180 thermostat is any real benefit from that?
What i have done:
4.10 gears, limited slip
built 4R70W, 3200-3500 stall
Sct chip tuner
BBK ceramic shorty headers, Full off road exhuast
24# ford racing injectors
CAI, 70mm throttle body , Stack racing plenum
CNC Ported PI heads with over sized valves 600 lift springs
stock bottom end
What cams would be best for that application?
This is the cams im looking at now are from modular head shop
0.050 Duration Lift at valve Centerlines LSA
46PI STAGE 3R 233/230 550/525 112/110 111
Also I plan to gasket match the PI intake manifold to better match the intake ports of the ported heads. Is that a good idea or is that just going to make the car a dog in the lower rpms?
Thank you for any help
twovalveterror
Dayton, Ohio
your build sounds similar to mine. what shop did your heads? the bump in compression is a good thing for a n/a build, but you will need higher octane fuel.
email nick at mhs with your goals and he'll tell you which cam to get. I wouldn't want to rev past 7k on a stock bottom end, but he won't steer you wrong.
sounds like you've got a decent list of supporting mods. I'm not sure how porting a plastic intake would go, if you really wanted to port an intake, I'd get something like the HPS for a stock style intake, or even the edelbrock if you're willing to rev enough to make it worth it.
hope this helps, and good luck!
mtang98 gt
mtang98 gt
No idea what shop did the work bought them used. I emailed nick to see what he says, I've seen some photos of people port matching the runners with a dremmel I don't think there is really anything to lose.
mtang98 gt
mtang98 gt
Well haven't heard from nick and its been quite a while.. I'm starting to worry if I should even order from him I was plann on Getn the stage 3r cams and have them degreed by him but I'm scared that I won't even get to drive my car this summer...
