procharged 4v swap comin along
Magic
Some time zone
RareBreed said:
good looking setup, how hard was it to do the swap? and how much did the 4v set you back? thought about doing that swap in the future instead of a SC, but worried about how much has to be changed to make it work.
Its not a very difficult swap if you keep the Coil Pack ignition.
N
ninety7_four6
yea its not too bad if you keep your ecu and harness...
next on tap is the rear end (true trac, 31 spline mosers,4.10's)
N
ninety7_four6
95convgt said:
Lets see some Dyno sheets and some 1/4 mile times :) Did you go on the safe side of tuning ??
i actually never recieved a dyno sheet.. i did watch one pull and it made 443, 1/4 times will come when the rearend is done
N
ninety7_four6
havent updated in a while but since then ive built the rearend with 4.10's and team z upper and lower control arms got it to the track a couple times and was runnin 11.87 at 116-119 with 1.8 60'.. lookin for drag wheels now
