ProCharger P1sc
96 blue moon
I am looking for the bracket so I can mount my procharger P1sc onto my 1996 mustang gt 2v. Does anybody have one laying around that they want to sell?
Magic
Some time zone
Call Procharger direct.... 913-338-2886... It isnt expensive to buy the bracket by itself...prolly around 200-bucks?
96 blue moon
I already called procharger and the bracket is around $260.00. I was just seeing if anybody had a used one before I purchase a brand new one. The bracket that came with the procharger fits a 2001 mustang gt so I need to swap it out. Thanks
ripper
That bracket should fit. The only dif between a 96 and a 2001 is the intake and heads. :dunno:
96 blue moon
I was told by procharger that the timing covers are different from the 96 and the 2001. The bracket that I need comes with the idler pulley mounted on the bracket and the bracket has a spot to mount my coil pack when I install my procharger.
Magic
Some time zone
yes that is correct, differences in timing cover.........
ripper
I put a 2001 PI motor in my 96 and used the same bracket to re install the s/c :dunno: The diff in timing covers is windsor or romeo. The idler pully isnt mounted to the bracket its behind it. And there should be 2 holes in the upper left side of the bracket that you mount your coil pak too.
Heres the idler pully i just changed it. You need 2 spacers. You can see one of them in the photo.
[attachment deleted by admin]
96 blue moon
I thought the only thing different from the windsor and the romeo engines was the valve cover bolt pattern but I am not sure about the timing cover. I take it you have the windsor motor in your car since you installed a 2001 PI motor. I don't see anywhere on my bracket that came with my procharger to mount my coil pack too. dunno: Do you have a picture of your charger on the car? Thanks
ripper
I have a Romeo engine. On the windsor timimg cover one bolt is bigger and you have to drill out the hole. Thats the only dif. I think maybe you have a 3v or 4v bracket. Ill go take a pic brb.
ripper
This photo shows were the coil mounts to the bracket ( right side)
ripper
This one shows the idler pully between the bracket and altenator
96 blue moon
Stevo, Thanks for the pictures and helping my out. I will send you a picture of the bracket that came with my procharger tomorrow evening as I have to work tomorrow. $ O.T.
96 blue moon
Stevo, Here is a picture of my bracket that came with the procharger. He told me it came off a 2001 mustang gt 2v.
96 blue moon
I am putting this on my PI headswap with stage 2 heads and comp cams. The lower end is still stock for now. I am only going to be running 6 psi of boost with a real good tune due to the haedswap. I did install multilayer headgaskets along with ARP headstuds.
ripper
Sorry man thats not a 4.6 2v bracket. Looks kinda like a 5.0 but im not sure. Show us a pic of everything you got from this guy. Then I can tell you what you need.
96 blue moon
There is a part # on the bracket so I will call Procharger tomorrow. I did give procharger the serial # off of the supercharger and they told that this unit was for a 2001 mustang gt 2v and when it was purchased. :dunno:
