ProCharger P1sc
ripper
You need alot more than the charger and bracket moon. You need alll the piping, the intercooler, 42lb inj's, 255 fuel pump, MAF, a CAI is good to have, and either a SCT 4 bank chip or the XCAL2. You need a new belt too. I have the part number in the shed ill get it for you latter. Be sure to get a GATES or Gatorback. Then you will need either a by pass valve or a blow off valve. I like the bypass. Vortech makes a good one I can get that part# for you too latter. Then after all that lol you need a good tuner and dyno time. ( I know you have some of this stuff allready just puttin it in there for other readers)
Another thing: Superchargers are not adjustable LOL. I know you want to run 6lbs of boost but a ps1 is gonna make around 10. Your stock lower will handle it but its lifespan will shorten some.
The key to a s/crd car is patience. Take your time and get all the right stuff. Stay out of boost till you get it properly tuned. In the end you will be more than happy with the results :eek:uttahere:
96 blue moon
Stevo, When I bought this procharger eveything came with it. I have a 3 core Intercooler. blowoff valve, all the piping to do the job, MAF, and the CAI. All I need is some 42lbs injectors and a good tune. I called procharger today and they told me that the bracket that came with the procharger is for a 02-04 mustang gt 2v. Everything will fit on my car except for the bracket and I knew this before I purchased this unit. Procharger is working with me on what pulley to use with my setup. They are not concern with my high compression because of the high flow heads and cams that I installed. I am going to take my time on this project since I have all winter to install it right and get my boost just right to take care of the lower end.
P.S. Know one gave me a line B.S. because I knew what I was buying for a very good price. Thanks for your interest anyway FUK_N_JUNK!!!!!
Whistler98
Southwestern, Pa
That car is going to scream as long as the tune is on it will hold up. Hope you find the right braket. I would just try getting one off ATI.
96 blue moon
Thanks Whistler98. I know that I am going to be on the edge with my motor. I will make sure that I get a real good tuner to tune this thing up. :thumb:
96 blue moon
Hey Stevo, Where did you get the ATI idler pulley that mounts to the procharger bracket and what is the part number. Also what is the part # on the serpetine belt. Thanks
voidfinger
Yea thats the bracket off the upper Romeo cars. They had a different front cover config... i think they had two tentioners on it and they didn't have coil packs... so i would just get the 96-98 bracket from them dude. Congrats on a killer set up :)
96 blue moon
Thanks. I think I found a good used bracket for my car. procharger has been working with me to install my procharger. :thumb:
