Professional Products intake elbow
Gtnut1996
i got one two or three months ago when they came off backorder. i think i paid 60 for it. i got it in and painted it to match the intake. when i went to put it on i had to grind a side on it for the t body to slide on. i cant remember what sensor was hitting it but it did.
Metrock
Yeah I had to grind a side off also. It was just a buldge off one side and you couldn't plug the sensor in. Wish I would have went with a different elbow. The only reason I bought it was cause it was cheap and figured they were all the same, guess I was wrong.
Venom351R
Maine
Get the trick flow one, the PP castings on the stuff they have is crap, cheap ass china garbage.
94IVGT
Northcentral, IL
for the price it is good. grinding the side for the sensor is not a big deal at all. Im a fan of spending my money on American made but this so called china garbage performs as good as the rest. I have had no issue making 635 fhp.
I don't recall having to grind anything for mine, I already had the polished TB so i wanted it to match. If your TB is larger than 70mm though you may want to go with a different elbow, you don't want it restricting airflow.
Win said:
I like the look of ours actually
+1 our TB setup is much more attractive than the fox setup, I remember the fox parts being cheaper though. I did see an SN95 TB mounted like a fox tb though, not sure what goes into making that work.
