Project Whiteout - drivetrain upgrade
FinnCobra
Finland Europe
Car is 1994 white Cobra, old drivetrain sold long time ago. I got totaled Mach1 for parts but I got scammed. Car has been in parts about two years now. But now I have most of the parts.
I have rebuild iron block, similar parts than in 03 Cobra. This week I'll get Eaton m112 with some parts. Current plan is to assemble the car NA because I need to get lower manifold and intercooler, and I need to get some savings first.
I have made irs swap few years ago, I have decent chassis. Subframe connectors, stiff bushes, bilstein, original brakes with Russel lines.
Before I can add the charger I must upgrade fuel pump. I have returnless system, and I plan to use either Mach1 or Terminator ecm. I have Quarterhorse and I have made several tunes for different Mustangs. HP goal is under 500, I have 47 lbs injectors.
white95
Apex Junky
Admin
Prairieville, LA
FinnCobra
FinnCobra
Finland Europe
I got low miles Eaton with plenum, tb and cai. Saving for more parts, intake and cooler next. I moved knock sensors outside the block, near engine mounts. I ordered some heat shielding tube for knock sensor wiring, I must wait for them to get wiring made.
FinnCobra
FinnCobra
Finland Europe
Pressure and temperature sensor
External gauge mechanism moved to original place.
Needle from old. Measuring 0-100 psi
FinnCobra
FinnCobra
Finland Europe
Picture links broken sorry. I had major problems and next goal is 2019 summer. Cylinder heads leak from bad surface milling(I hope so, next thing would be crack). I got some more parts. Swapped injectors 47>54 because I got good deal.
FinnCobra
FinnCobra
Finland Europe
Yes, it's in metric scale. But feels very fun to drive. Engine in break-in period, rpm limited to 6000rpm, dyno rpm calculating has error more than 500 rpm.
ECM is little hard to tune, maf and injector limits are so small that everything has to be scaled.
