Pulled a code on the stang how to fix it
95gtdrop
sacramento
Pulled a 332 on my car today. It means insufficient egr flow. But how would I fix that? Everything seems to be hooked up and the tube is tight on the header and egr valve. :dontknow:
98-5.0
did you blow air through the pipe from the egr to the header...those can get cloged...take off the egr so you can see the pintle in the middle...hold a steady vacuum on it and see if it leaks down...that will tell you if the diaphram is leaking causeing it to close up .....also...check your position sensor...only good way to measure that is to put a volt meter on it and do a sweep for resistance.....ie...slowly moving it inward and outward and see if the values are smooth and gradual or if theres a dead spot in it....hope this helps...
95gtdrop
sacramento
will clean it out this weekend . My cat runs gret even with cel on. Will this damage anything? I am goin to be putting my cobra upper lower on this weekend also. There's a guy selling a used egr for 20 bucks. Should I get it just to have around? What setting in the volt meter do I need to use?
Thanks
sbr420a
if you wait a couple weeks i will have one off of my car. just pay for shipping anf you can have it
sbr420a
yeah no prob. as soon as i get a set of fox headers its urs. just gimme some time.
