Pulling engine
Dave5.0
Hampstead Maryland
Hey I'm new on here and I already have some questions. To start, when I pull the engine is it better to remove with the mounts on the block or just remove hardware off the mounts. I have already tried to remove nuts off the stud and it's a royal pita lol . just looking for some thoughts.....
ivan12
I usually use a couple of extensions and some 1/2" drive sockets with a breaker bar or impact gun depending on the angle. Just take it out any way you can, but I do recommend putting the engine mounts on before you drop it back in as this will give you a better chance to slide in place the first time.
g36 monkey
Orlando, Fl
I thought removing the nuts on the stud was the easiest thing to do. I had to do it a number of times on mine lol.
Musturd
Undo it on the studs yea it sucks you can only turn the nylock but a half a turn at a time usually an it's uncomfortable if ur on the ground but it has to be done
g36 monkey
Orlando, Fl
I found them easy to turn, but as stated could only get a bit at a time. See if you can find the size nut, then get a ratcheting wrench in that size. will speed up the process
Musturd
Yea do do we you just gotta undo the studs but honestly I just drop the k member normally takes no time
rz5.0
Great state of TEXAS
If you have a lift you could drop it. I took all of loose cus I didnt want anything getting cought I left all my ac stuff hook up and tranny came out also..
Dave5.0
Hampstead Maryland
Hey guys I got them tonight no problem. I just used the stud method.I think last time I tried I was just running out of patience lol. Thanks for the pointers . This forum is great!
Jerry santos
