pulling my engine
phantom09086
Germany / Maryland
On Sat I am going to pull my engine, I have a engine lift, but dont have the sling just chains. Whats the best way to pull it without causing damage. any help would be great.
Thanks
Greg
Addermk2
remove the front accessories. lift from the front and rear of the heads. I made lift plates specifically for doing 5.0's, they have 5/8" holes so I can bolt them to the thermactor ports, and I lift using a chain.
castine917
wyoming, mi
mine has a lift hook at one of the head to exhaust. i have used that or bolts into front and rear of heads. there is also an option off buying a plate that bolts to your lower intake manifold.
i recommend a blanket over the front bumper to keep lift from rubbing and scratching it if it gets to close or rolls.
Paul
A couple of 5/8-11 bolts in the cylinder heads (front and back) will serve as good lift points. Cheap too.
94svtturbo
I have always wondered if it would be safe to make a lift plate that's bolts to the lower manifold? It seems a little sketchy using 6 smaller bolts in a aluminum manifold but people do it with carb manifold all the time and it holds up
Paul
I have the lift plate that bolts to the lower intake - works like a champ.
