Deeplist I appreciate your vast knowledge in so many areas but not sure this is the area to speak up on. Just adds confusion as you are giving bad info that will confuse him.
If you have the mach460 system and take the rear enclosure and amps you you will loose the bass as the amps there are for the front/rear woofers. The drivers side does the rear woofers and the pass the front. At that point the only speakers you would have to play would be the 2.5" tweeters and it would sound pretty bad. You can replace the speakers if you have replaced the deck already but there is NO(zip/zero/zilch) to gain from running new wire. No matter what stereo you have the wire is already there, easy to find and will net you no gain in sound by running new.
Sorry, there was no mention of any mach system in the OP.
And yes, the quality of speaker wire DOES make a difference. Of course he doesn't
HAVE to run new wires, it was a recommendation. Speaker wires vary greatly based on quality, price, and purpose. Speaker wire is described by three properties which determine its performance: resistance, capacitance, and inductance. Resistance increases with the length of the wire. The wire's resistance has the greatest effect on its performance. The capacitance and inductance of the wire have less effect because they are insignificant to the capacitance and inductance of speakers. Larger speaker wire (smaller gauge) will have less resistance. As long as speaker wire resistance is kept to less than 5% of the speaker's impedance, the wire will be adequate. Naturally, high-power audio systems using 2-ohm speaker circuits require thicker wire than 4 to 8-ohm applications would.
Here's a guideline that I typically follow:
16 gauge is good for tweeters
14 gauge is good for typical speakers
12 gauge is good for low power subs subs
8 or 10 gauge is good for high power subs
