Question about supercharged 94/95 Cobra
osofast
I'm putting a Vortech S-trim on a stock motor'd 94 Cobra. I'd like to know what pulley size is making what kind of boost. At least a ballpark figure.
SvtBlack95
the stock 3.33 pulley that comes with the kit will give you 8 psi i went with a 3.00 and im seeing 12-13 psi with the powerpipe
Skritt
You can pick up a UPR powerpipe for around 120 bucks plus its not alum. its made from abs Plastic so less heat.
Maniak87
i couldnt get that bitch to fit!!!!! ended up getting the anderson one.
scootin95gts
what 1/4 mile times are you guys running with the vortech charger on your cars and also what mods? Cant decide between a centrifugal charger or HCI
Maniak87
do the s-trim!!! doesnt really cost that much more and you will get way more power! it will find weak links alot faster than a HCI motor though.
ive started a thread a while back comparing the two. hit up the search, this is a very common question.
