Question concerning oil temp
Mean98GT
I have an oil temp gauge to install. Its autometer, and electric. Im wondering if I can get the right fittings together could I put the sending unit into the oil pan plug? (I'm speaking of the bolt that you remove to do oil changes).
Thanks.
Paul
+1
The oil pan plug is supposed to be just that, a plug. Putting a big fat (or... tall) sending unit there risks it getting torn off. Also, it's not really designed to be continually removed/installed. This is what I cautioned you about when you bought the gauge - you need a port in the pan to install it. You said that you had an aftermarket pan and everything was taken care of?
Mean98GT
Turns out the aftermarket pan does not include a port for the sensor. Looks like Ill be dropping it off with huber for the tap in the oil pan.
