Quick Exhaust question.
Twista
Now i done changed my midpipe million of times, but i've always used the mac paper gasket. I brought acouple ford gaskets but always had bad luck with them.
Right now my current mac paper is bust so i need to replace it. Im using a ford gasket, but im unsure which way it goes in.
The part with the black o ring'd lip around it.. does it go into the header or into the midpipe?
no gasket needed but the where the headers bolt on to the heads.
or ive never used one before :dontknow:
i suggest putting the lip into the header. it will aid in "holding it in place" if you dont have a free hand. It will also help prevent clearance problems if your rear part of the mid pipes are already connected.
I'm using a ford gasket right now and i'm 110% satisfied.
T
Twista
Duff Daddy said:
ive honestly never used a gasket ahhaha
You must have a huge nasty leak rofl. The passenger side header to midpipe needs a gasket.
tazmanhawaii
Just put that same gasket on my car. I put the lip towards the exhaust manifold. Not sure if it makes a difference as it compresses the gasket and both the mainifold and the midpipe have an indention for the gasket. So far, not exhaust leaks, so I guess I got it right or was lucky. :thumbsup:
