Rack Bushings
94Pro-5.0
Little Elm, TX
19mustang95
I have the energy ones and they are great. I also had some aluminum ones and they were great as well. I only went with the energy ones because they were the offset ones...
SRT Handz
I want the MM aluminum Rack Bushings...I Have heard nothing but good things.
19mustang95
If you are lowered, i would get the offset ones. It will help correct any bumpsteer problems you may have from being lowered.
Ciotti
Absolutely do not get the poly offset bushings, I had them in for 6 months or so and they were so much worse than the stock rubber bushings it was scary. I now have MM aluminum's in and they are incredible, MUCH less tramlining, much crisper steering feel, and loads quieter.
To quote MM's website...
"We don't recommend offset rack bushings for stock K-Members...
Offset steering rack bushings move the rack far too much on stock K-Members, and make an acceptible situation far worse than if you had done nothing at all. See our test results in the July 1993 issue of Super Ford, the September 1998 issue of 5.0 Mustang."
When I switched from my stock rubber bushings to the offset poly's my tramlining got worse and there was really no more of a positive feel to the steering. The problem with them that both of the articles discuss is that because the bushings are free to rotate in the steering rack, they will spin to the left a right a bit when steering forces are applied much like the stock rubber bushings squish to the left and right.
The new style MM solid bushings have a spherical bushing on the back that allows the steering rack to flex with the k member when it twists and vibrates so you will not get any of the harshness normal aluminum bushings create, but it does not allow the rack to move left and right when turning forces are applied which is why it reduces tramlining so much and gives such a crisp steering feel. As long as you still have a stock steering shaft, the rubber rag joint bushings in there will eliminate any and all vibrations and harshness from the steering, I drive my Cobra 20,000+ miles per year on horrible NJ roads and my MM aluminums have been the best mod I've done thus far, they are absolutely flawless.
