Radio Installation
New 5.0
Ok, I have a 95 GT. I just bought a radio and need to install it. One problem, the antenna wire that was connected to the original radio, cut in half. i have thought about splicing the wires and rewire it but I am missing the plug part, the part that plugs into the back of the radio. Does anyone know what steps I can take to fix this?
Thanks in advance
Steve
you can buy a new tip and solder it on, it is called a motorolla end I believe. The other option is that if you look behind your glove box you will see the ant go back behind it and out throught the firewall. Just before it goes through it will have a connector on it that you can disconnect the bad piece from. Check out your local audio or autoparts store and see if they happen to sell an extension, should only need 3-4'
