Raise my car!
screaminlegel
98 cv 3.8 auto
I want to raise the car 1/2-3/4" is there a past article or new thoughts?
CC'S95GT
Hampton ,Ga.
We need to know more about your suspension.
Stock springs? lowering springs? Isolaters in or out?
Welcome to the insanity.
screaminlegel
stock car with a broken front spring
the hose is a good idea but not for me
CC'S95GT
Hampton ,Ga.
Leaving the broken spring in there shouldn't be an option either.
You can probably find a used pair of stock springs for cheap if not free.
Where do you live?
Yeah, just get new stock springs for like $25. If that's still not high enough, get coilovers.
g36 monkey
Orlando, Fl
Pretty sure my coil overs even all the way up were not as high as stock.
Can we see a pic of how your car sits?
SVTstang96
Dubuque, Iowa
You cant really gain any height using a coilover on our mustangs since the upper perch for the coil spring is mounted to the top of the strut. The strut will max out before you really are able to gain any height.
hotmustang95
Boynton Beach FL
Is there a reason why you want to raise the car more then it is? These things look like trucks from the factory. I can't imagine going higher unless your going mudding.
screaminlegel
I travel the coast of Maine 150 miles a wack and pot holes and frost heaves rule.
I have a doner car for a stock v6 spring- I was wondering if a v8 car had taller or stronger springs?
the comment about the strut limiting has me wondering about other options?
or after market.
I need a little more ground clearance
g36 monkey
Orlando, Fl
the factory GT spring is a little firmer than the v6, so if you have a gt, the stock v6 spring would make it drop slightly. Like, so slight you probably wouldn't be able to tell. However, a slightly softer spring is worlds ahead of a broken spring.
EdgarR213
Staff online
