Rear gear question
Stock982v
Houston , Tx
Ok guys if I bought a differental with 4.10s already on them , what else would anything else special need to be done , could I install it or would I need to take it to a shop , and I plan on buying the bearing kit if this works out
Staff member
To do this, you will have to check pinion depth. Thats the hardest part about the whole deal. You have to press the pinion bearing on and off until you get the depth right.
98DesertGT
Homestead Meadows, TX
I've had hit and miss success with taking everything out, measuring, and reshimming as close as I could.
Sometimes it was within spec...Sometimes more tedious methods were mandatory
