Rear Upper Control Arms - 1998 V6
BingoMustang
My mechanic put a list of parts together that my car needs.
I need to replace the rear upper control arms and also the bushings to at the top of the differential.
Im travelling to the US shortly and normally order on RockAuto but they only have front control arms.
Hope someone can help me find rear upper control arms and the bushings for top of diff.
Thanks
shovel
The rear axle upper bushings are ACDelco 45G11049 - hopefully your mechanic also has a proper tool to push the old ones out and push the new ones in. Because of the way they sit, a typical bushing press won't fit. Here's an example of the kind of tool that's used for both removal and insertion - https://amzn.to/4hy69yc
OEM style rear upper control arms are available a couple different ways:
NPD brand #M-5500-5B (most parts stores can order NPD) - sold EACH so you would need 2 of them.
TrueDrive brand #SET-RF28150037-2 (pair, way cheaper)
Maximum Motorsports #M-5500 which is probably just the NPD brand in a galvanized finish (vs black)
You can google those parts up I'm sure and find whoever you'd like to order them from.
As an Amazon Associate we earn from qualifying purchases.
shovel
I don't know what's up with the TrueDrive brand but the upper control arms in back are the same 1979-2004 . The lowers changed (bolt size) from 98 to 99.
B
BingoMustang
I think I may go with you, and just order them from TrueDrive, I checked Maximum Motorsports #M-5500 and they are 1979 to 2004
