Ring and Pinion
Vettn71
North Richland Hills, Texas
I am looking to purchase a ring and pinion to install in my 95 GT. Since this is just the gear, not the differential do I have to worry about spline count? I wouldn't think so, but some posts seem to say that
TIA
Jim
CC'S95GT
Hampton ,Ga.
the yoke will come off your current pinion and reinstalled onto the new pinion.
So YES the spline count matters.
kb1982
Kentucky
Your question is kinda vague. Are you referring to the axle spline count? 28 is the most common, but some vehicles came with 31 spline from the factory. Its the carrier(posi unit, locker, spool, mini spool etc.) thats bolted to the ring gear that will determine which spline count axles you need. If your talking about the spline count on the pinion gear that the yoke flange mounts to, its a 28 spline. There are different yoke flanges, and they feature 30 spline count but have different bolt patterns and allow use of bigger u joints. Mostly found in trucks. http://www.hotrod.com/techarticles/drivetrain/1308_ford_rear_axle/
Vettn71
Vettn71
Good information on that link. So are there aftermarket yokes, I guess for 30-spline pinions?
kb1982
Kentucky
There sure are. And they are fairly cheap. The 35 dollar range, and can be bought to fit different bolt flange sizes and for different u joint size, if you need it, its out there.
the5.ohh
Shaolin, NY
While your doing gears (ring & pinion) make sure you get new axle bearings, and should get a ford racing t-lok rebuild kit while its all open. Oh and if your 95 is an auto, get 4.10s. I did them in my 95 GT auto, and its a huge kick in the ass
Cpotts13
Biloxi, MS
Like he said, you only want to pop that sucker open once, you will know why. So why you are in there do a full rebuild, including all bearings and axle seals. It is super cheap insurance. Even if you have a manual do 4.10's.. You will thank us later..
