Routine Maintanence ?'s
IEC Stang
I think instead of getting another mod i'm going to save up and do some maintanence on my car, because well frankly i think it needs it. So i was just wondering what things to do? I am going to change the spark plugs, tranny flush, new windshield wipers, new balb for one of my fog lights, radiator flush, and probably change out the fuel filter. Is there anything that i'm missing? Let me know thanx :)
NERD
Virginia
96sohc said:
Bleed brakes.
It's funny people never think of that... lol I'm an over bleeder, every year no matter what. What goods HP if you can't stop it. :thumb:
voidfinger
new spark plugs , wires , pcv valve , egr valve , fuel filter , air filter , etc etc etc
voidfinger
sxynerd said:
96sohc said:
Bleed brakes.
never heard of bleeding every year... why would you do that by chance?
Jrgunn5150
voidfinger said:
sxynerd said:
96sohc said:
Bleed brakes.
Get any air that crept in out.
I
IEC Stang
Thanx guys for all the info. Yea i was going to bleed my brakes too cause i think they need it. I already changed my spark plugs and winsheild wipers too today. Little by little i'll git er all done, then i'll feel a lot better about my car. :thumb:
96gt226410
Every year is a little excessive, but there's no harm in it. Brake fluid is hydroscopic (that means that the fluid absorbs water :thumb:). Brake fluid that is semi-saturated with water will not hold the characteristics of clean brake fluid. Your car won't stop as well because the water will make the brake fluid evaporate some and it can also cause rust to build up in the metal lines... Wow, I feel smart. :coolsmiley:
Mr. OAM
Next, open your glove box and pull out the manual. There is a complete maintenance program for your car published in there under the recommendations of the people that engineered your car.
Steve
Jrgunn5150
Steve
You mean airfilter's and trans filter's aren't good forever? That someday I need to change the oil in my rear end? Insanity!!!
voidfinger
J.R. said:
Steve
i know i'm asking for trouble but i haven't changed the rear end fluid since... well 50k when the original gear set went out and had it under warrenty lol.... o well... how much are you suppose to change... it? every 100k? is so then i'm only like 20k behind :tickedoff:
