RPM sudden surging
akaNYr
Washington state
I have a 95 Mustang GT 5.O SN95 with randomly surging RPM's for months. It starts 20 minutes after I start driving. The car don't move any faster but will jerk then bang when the RPM surges kick in, anywhere from 1000 to 2000 above normal. I changed cracked vacuum lines, cleaned the MAS & throttle body 5 times, lubed the springs & cables on the throttle body & cleaned and tested the iac, none fixed it. I tested the (non adjustable) TPS, it wouldn't go below 1.09v throttle closed and 4.85 wot. I bought a new (non adjustable) TPS & it reads 1.38v throttle closed. Car has more power & responded better but RPM's still surge, and NOW when idle RPM bounce between 800 and 1000. I set it for 750rpm. Nov.2018 I got codes 56, 45, 64. I don't have coil packs (code 45). Since then the only code I get is 564 (electric drive fan fault). The radiator fan goes on alot sometimes, the car shakes a little and volts go up. Any RPM help would be much appreciated.
Silver95bird
Radiator fan acting weird plus surging makes me wonder what shape the ECT sensor is in. Check it's resistance, wiggle it and see if it's steady, check the wiring harness also. If it's failing and going sky high, it'll trip on the fan as a fail safe.
07GtS197
Fort Myers, Fl
Do you have an auto? It sounds like its downshifting. But the idle rpm bouncing wouldnt be related. Ect is a great place to start. Does your smog pump work?
akaNYr
akaNYr
Washington state
Thanks guys for all u r advice. I'll check the ECT and harness. It is an auto tranny and I have no smog pump. Cars over 15 or 20yrs old don't get inspection. So now 3 people have told me to do a smoke test. After I got my car back from the garage that did the vac lines I had a feeling everything wasn't on the up now up with this guy. ECT, harness check n smoke test it is. I'll fill u guys in when done.
07GtS197
Fort Myers, Fl
I would say that one of your problems is either a bad or misaligned mlps. One common sign Ive seen is the trans falling out of overdrive at highway speeds.
summerstang95
Any luck on getting the problems fixed? Mine is doing the same thing.
