Running Lean?
blkmcnasty
Illinois
I just finished installing a summit o/r h, which by the way made my passenger side exhaust tip recess behind the bumper and now looks like shit (horrible fitment). But anyways when i pulled the O2 sensors to put on the new pipe, the drivers side was black on the end and the passengers side O2 was pure white! What the hell does that mean and how do i fix this?
Jrgunn5150
Loosen up the clamps and fix your tailpipes, it's not uncommon that you would have to do that...
LAFENATU
+1
Not many exhaust setups in this world fit 100% perfect. You usually have to fvck with them a little.
Steven
SC
ones burning clean, the other is a little worse obviously. Leans not always bad, lean is fast, to lean is deadly.. lol. Your car will be fine. If anything your lacking or getting to much fuel on one side more then the other
B
blkmcnasty
Illinois
would the one side be running more lean because of clogged injectors or is it an ecu fault? I could also just be paranoid becuase the car runs so smooth and strong, never any misfires or stumbles at all!
Steven
SC
I wouldn't worry about it then. The only way to truly know if its running lean is to have a wideband on the car and check. Otherwise it's a sniff here, look there type of deal as to the A/F ratio
Jrgunn5150
I think you're paranoid, that's why I didn't answer to begin with.
96GTPlanB
