Dr.Scientist
- Joined
- Apr 2, 2011
- Messages
- 273
- Reaction score
- 0
My 94 GT is having some cooling problems. In the Texas heat, the needle sometimes gets over to the letter "M" on "Normal". On the heat gauge. Not quite hot, but warm enough to make me want to fix the problem before it gets any worse. To me its a problem, cause on my other 94 GT, it never once got past the "N" on the "Normal".
So I hear that water has a better heat transfer rate than antifreeze. Right now I'm running a 50:50 water to antifreeze ratio. What is the safest ratio to run? I know the water pump needs some of the lubricants that are in antifreeze. I think I've even killed a water pump, using only straight water. So I need to know what the safest ratio is.
