Scraping/grinding noise coming from bellhousing.
97_slowbra
Scraping/grinding noise from bellhousing. Had it out numerous times, replaced everything each time. Start it and run it for a few minutes and the noise and gone, the it comes back and never goes away untill I repeat this process. (Cannot add video of sound here. And it’s hard to explain the sound)
Auto or manual transmission?
When you say “replaced everything each time”, could you outline the parts that you replaced, please?
97_slowbra
97_slowbra
Manual. T-45. Clutch, pilot bearing, and Throwout bearing every time.
Have you done anything with the flywheel?
So the noise is gone but comes back a little while later. Does the noise change at any given time? On the clutch, off the clutch? And certain rpm?
97_slowbra
97_slowbra
No change when on the clutch or off. I have the proper flywheel. It is not noticable after 2k rpm but my car is also straight piped so I can’t hear anything
the way you can video is you tube it
i would try somewhere else
Iwarrior1016 wasn't there a place you were getting them from
i try to get mine through ford
i have had bad luck with some auto zone ones
never did try Orielly's
Mysticcobra
