When mine had a hanging throttle, I traced it to a dead spot in the TPS. You can use a multi meter to test it.
A base idle reset might also help.
^ This.
While cleaning the TPS and IAC sensors could help, making sure the TPS voltage is correct AND as CC'S95GT stated, making sure there are no dead spots in the TPS by keeping a voltmeter on it, and slowly opening the throttle blade by hand (engine off) and looking for a jump in voltage.. With the blade closed the voltage should read 0.97-0.99 volts, and should smoothly increase as the throttle body blade is opened (I can't remember what the final number is, maybe 5 volts? (just a guess on that part).
