When in gear my shifter still has some play to it. For example, when I'm in, let's say, 3rd gear, I can still wobble the shifter around a little? Normal or something to worry about?
Yea the stock shifter is a big rubber stick. I find aftermarket shifters forsale all the time around mustang centered classifieds. $50 is the going rate for most
I thought you put a short shifter on in your build thread though?
I can tell you, my car never wiggled around in gear with my MGW, no more than say 1/8 to 1/4" of travel.
How much slop are you talking about here? It should not feel like an old VW bug where you can't find neutral because every gear you can move the shifter 6 inches side to side lol
There is a small nylon cup in the transmission where the shifter "ball" interfaces with it. When it wears its good for a few mm of play in any direction.
The econoshift isn't really a good piece. I helped a friend put one in his car and it literally fell apart. Has the play been there since the install or has it progressively gotten worse?
As long as that rubber bushing is in good shape or it will be crappy too. Did you verify the bolts that hold the handle (not the knob) to the shifter are tight enough? My pro-5.0 used to loosen up from time to time
