Short Exhaust Vid
CROSSBREED
Got rid of my Mac mufflers today and went with straight pipes. The sound of the V6 is really starting to grow on me, definitely doesnt sound like your average sixxer. Let me know what ya think!
[video=youtube;jXqxMe3A4aM]http://www.youtube.com/watch?v=jXqxMe3A4aM[/video]
robb15033
Northern Va.
Wow. Nice job with the car man! Can I ask, how/where did you get direction on putting the engine together like you did. Having a V6 myself, I know how limited it is to get any direction on how to build up the engine or where to get the parts. SSM and VAP are a couple of spots out there. I was thinking about contacting GSSmotorsports for specs on parts.
C
CROSSBREED
The guy I got the car from is the one that built it. Not sure where he got his direction from, but im assuming slot if it from V6Power.net and SCCOA. It's basically a supercoupe powerplant in a mustang. I'll put up a complete engine parts list for you when I get home.
C
CROSSBREED
Here's the engine mod list
4.3 "Long Rod" Stroker (Super Six Motorsports GA.)
99-00 4.2 block balanced, bored and torque plate honed, decked, align bored, internal Glyptal treatment
8.7:1 Wiseco forged pistons
Wiseco rings
6.125 Scat H-beam rods
ARP rod bolts
Delta billet cam 208/216 .50/.50 112
Ford MLS head gaskets
Felpro gaskets
ARP head studs
Stage 3 Superheads - Super Six Motorsports (Supercoupe cores)
Compcams 942 Stainless Valves 1.85 Intake
Compcams 942 Stainless Valves 1.55 Exhaust
Compcams 942 Springs
1.73 Harland Sharp Adjustable roller rockers
TrickFlow 7.050 hardened pushrods
Hydraulic roller lifters
Ford timing chain & tensioner
Ford pan, girdle, studs, pickup, dipstick and tube
Magnum Powers M90 Supercharger
85mm Magnum Powers TB
90mm Magnum Powers inlet and 4" K&N cone filter
90mm Lightning MAF
Ported manifold and inlet plenum
Magnum Powers classic raised top
Magnum Powers front mount intercooler
SPAL 16" radiator fan
SPAL 14" pusher fan
Custom aluminum radiator
BBK adjustable FPR
BBK 255 HP fuel pump
Accel fuel pressure gauge
60# iSiemens / Mototron Deka 4 fuel injectors
BHJ harmonic balancer
SCI stock size pulley set ( water pump / alternator)
SCI stock size Jackshaft pulley
SCI 10% blower pulley
SCI a/c delete pulley
Magnum Powers 10% overdriven crank pulley
Heartland power steering pulley
Ford plug wires
MAC ceramic shortie headers
Melling high volume oil pump
Spec aluminum flywheel
Center Force dual friction clutch
Ford aluminum driveshaft
8.8" rear end w/ FRPP 3.73 gears
Steeda Tri-Ax shifter
SCT Xcal2
Taylor battery relocate to trunk
